Best Vette Yet
I have a 2003 C5 Coupe with 42,000 miles on the clock. I am experiencing cooling issues. Normal freeway driving gives me 195 degrees. If I go into the mountains where the engine is working fairly hard or traveling at suburban speeds (30 - 45mph) the temp gauge climbs to as high as 235 degrees (one time only before I shut the motor down). I have checked my codes but the only code I have is 0101 which is a MAF code. I am not sure if my fans are running correctly. Is there a way to check this? I leave my aircon running to try and keep the cooling fans running. The aircon blows cold but the motor still warms up. Any ideas? Waterpump...perhaps? :confused
BTW, the 2005 C6 vette with the electrical issues has been running flawlessly...thank you for your assistance in solving those problems.
