tchort
Hi everyone, I just came across your forums while researching this problem that's been making me lose sleep for the past several months. I think if there's any hope of me stumbling across the solution, it's sure to be here.
I am the proud owner of a '88 Z51 4+3 that my girlfriend appropriately refers to as The Batmobile. I also invested in a GM shop manual for the car (more on this later).
Here's the problem: The auxiliary fan refuses to turn on. The fan itself works. I give it 12 volts and it comes on fine. But, it does not come on when I turn on the AC. Also, it no longer turns on in Diagnostic Mode when I jumper A and B on the connector under the dash. Instead, what I get in Diag Mode is a fast clicking sound coming from somewhere near the top of the engine, under the TPI.
I know this is probably caused by low freon in the AC system. But what is confusing is that the fan no longer comes on in Diagnostic Mode either.
I sure would appreciate any help with this. The GM manual is complete garbage (with all due respect). It makes NO mention of a fan switch on the left side of the engine that controls the main fan.
Thanks in advance.
Thanks in advance.
ad I ended up physically tracing the wires back from the fan, through the harness. Turns out the relay for the larger fan (the one behind the radiator) is located under the cruise control servo, between the wheel-well and the battery. There's two relays there, and I have no idea what the other relay is for.
otfl
