B
Bob Yates
My 86 vert is my dailey driver and if you could see my waist size you could tell I spend a lot of time idling in fast food lines. While I'm making my mouth water thinking about all those carbs I'm getting ready to injest I spy my temp gauge. It goes up to 225 degrees and my fan kicks on and cools it down to 205 degrees. I always manage to get behind some one who is ordering food for the eastern half of the United States,so my fan keeps doing it's thingy. I like many of you get Corvette catalogs. I'm always looking for items to make it better. One of those items was an Auxiliary Fan Kit....A must for cooling it reads. This fan kicks on at 200 degrees and off at 185 degrees. I run a 180 degree thremostat and keep the raditor intake air area clear of junk so that area is clean. I purchased one of these kits. I have two problems. Here's the first...the fan switch that came with the kit kicked on at 190 degrees. The fan started but the temperature kept going it's merry way til the main fan kicked in at it's normal 225 degrees and cooled down to it's normal 205 degrees. I called the vendor's customer dept. and talked to a tech. He said he would send me a new fan switch and he did. I installed it as per instructions and this one comes on at 186 degrees. I called back and told him of the out come. His responds was he finds it hard to believe that two switch would be bad . HEY jack believe it. I've got'em. I told him I was more interested in second problem. Why isn't the temperature going down when the auxilary fan kicks on. He told me to check the flow of air going thru the radiator. It's coming thru but not with a lot of force. Has anyone had this problem? If so were you able to correct it. Maybe I need a new water pump? I only have 57,000 ticks on the clock. The car did a lot of setting in it's day. Thanks to any an all for help. .... Bob Yates
