- Joined
- Jan 1, 2002
- Messages
- 7,246
- Location
- Washington, Michigan
- Corvette
- '67 Marina Blue Convertible
Joe has it nailed - do NOT remove the thermostat; it provides a calibrated restriction that establishes the correct coolant flow rate in the system. The Robertshaw "balanced flow" thermostats are better than the stock type; if they fail, they fail open - stock types fail closed.
99% of the time, only two things are responsible for cooling problems - inadequate radiator heat transfer capability, and inadequate airflow through it. Period. In 40 years of solving cooling problems, I've NEVER seen a water pump as the cause of a cooling problem. All the whizbang hot-rod race-car shiny water pumps in the world won't fix a cooling problem caused by a radiator that can't handle its job any more (and almost all of them "look good" from the outside). If you don't run a 50-50 anti-freeze/distilled water mix and change it every two years, you're cutting your radiator's life in half. See it all the time. The anti-freeze protection doesn't wear out, but the anti-corrosion inhibitor package does, as it does its job; internal scale and corrosion (which is invisible) are a radiator's worst enemy, and the only protection against it is fresh anti-freeze.
Forget the "Water-Wetter" and other "miracle potions" - solutions to cooling problems come in boxes, not bottles.
