correct a/c for the 67 427/400
ZRGator
Gone but not forgotten
West Friendship, MD
1993 40th ZR1, 1967 Red 427/400 coupe
Does anyone have any good pics or know of the identifying marks/numbers I should be checking for on my 67's a/c compressor? Also. how about the decal for the compressor? What info/markings should it have to be correct?
from the Judging Guide which I happen to have right here :D
"All Factory installed compressors are of an axial design, model A-6, manufactured by Frigidaire. The compressor is painted semi-gloss. All compessors have a foil sticker with model number 5910645 and a date code. The date precedes the car assembly date. The date formate is MMDDYS. There is also a casting date on the end plate of the compressor assembly, just under the manifold outlets. The date code precedes the date on the frigidaire foil lable. A natural finish AL mufffler is attached to the rear with a single bolt and a thinck flat washer. A single shraeder value with cad or a zinc plated hex-cap is located on the outboard side of the muffler."
Hope this helps,
TomM
