Complete Coverage - No Deductible
The warranty I purchased at the time I bought my '98 is available through dealership sales only - not to the general public. So I spent some time surfing and reading.
I just purchased a Supreme Plus Warranty for my '98 to go into effect at 49,000 miles (the point at which my old warranty ends) from Extended Auto Warranty Corporation. Here is their website:
click
I had my car at the shop yesterday and took the coverage printout to Kevin for him to look over. He said it was a good warranty so I bought it.
I checked WarrantyDirect.com, but they do not warranty cars 1998 or older at this time.
A couple of things I liked about this company...
There is no waiting period. If you do not have a current warranty, they send an inspector out to examine/inspect/drive the car and verify the mileage. He then writes a report and notes any issues which presently exist. These issues are noted and are not covered until they're repaired by the owner. But barring that, the car is covered from Day 1.
If a current warranty IS in effect (as it is in my case) there isn't even an inspection. The new warranty simply goes into effect upon termination of the old one.
They pay the bill with a credit card - your mechanic will like that - no waiting for "check's in the mail!"
They're also members of BBB Online and WebAssure.
Friendly folks too. I sent an email inquiry overnight and received a prompt response the following morning from the president of the company answering my question. When I called today with a follow up question the salesman I talked to yesterday was out to lunch so I left a message for him. About 10 minutes later, the president called and introduced himself. He asked if there was something he could help me with. After he satisfactorily answered my questions, we finalized my purchase. And he's a Corvette fan too!
I am admittedly nervous about such a large purchase... in fact, I'm getting butterflies while I write this. Hopefully all will go well. If it doesn't - believe me - my Corvette friends and family here will be the FIRST to hear about it!
From the website:
Supreme Plus Warranty - Complete Coverage*
*may be slight differences based on model year.
[FONT=Geneva, Arial, Helvetica, san-serif]
Engine:
All internally lubricated parts inclusive of: pistons, crankshaft and main bearings, connecting rods and bearings, camshaft and bearings, timing chain, rocker arms, shafts and bushings, oil pump. The engine block, cylinder heads valve, valve covers, timing cover and oil pan are covered only if damaged by one of the above internally lubricated parts. [/FONT]
Transmission/Transaxle:
All internally lubricated parts contained within the transmission/transaxle case, torque converter and vacuum modulator. The transmission case and pan are covered only if damaged by an internally lubricated part. [/FONT]
Drive Axle:
All internally lubricated parts within the rear differential housing, drive shafts, axle shafts, universal joints, yokes, constant velocity joints, wheel bearings, and carrier bearings. The rear differential housing is ONLY covered if damaged by an internally lubricated part. [/FONT]
Seals and Gaskets:
Cylinder head gaskets and intake manifold gaskets. All other seals and gaskets are covered only in conjunction with a covered repair. [/FONT]
Electrical:
Starter, starter solenoid, alternator or generator, voltage regulator, windshield washer pump, wiper motors, factory installed antenna motor, trunk lid motor, factory installed sun roof motor, ignition control module, power seat motor, window motors, power mirror motors, door lock actuators, speedometer, tachometer, oil pressure gauge, water temperature gauge, convertible top power motor, factory alarm, instrument cluster and factory installed radio. [/FONT][FONT=Geneva, Arial, Helvetica, san-serif][/FONT]
Enhanced Electrical:
Map sensor, mass air flow, throttle position sensor, oxygen sensor, coolant temperature sensor, vehicle speed sensor, camshaft sensor, crankshaft sensor, climate control sensors, electronic control module, climate control module, fuel injection control module, power train control module, cruise control servo/transducer, cruise control module, and cruise control amplifier.[/FONT]
ABS:
Electronic control module, hydraulic pump, accumulator, pressure valve, isolation dump valve, wheel speed sensor, and reservoir.[/FONT]
Air Conditioning:
Compressor, compressor seals, compressor clutch, receiver/dryer, and air conditioning condenser.[/FONT]
Cooling System:
Water pump, thermostat, radiator, electric fan motor, fan & clutch, blower motors, and heater core.[/FONT]
Fuel System:
Fuel pump, fuel pressure regulator, fuel injectors, fuel sending unit.[/FONT]
Brakes:
Master cylinder, vacuum assist booster, brake calipers, wheel cylinders, compensating valve.[/FONT]
Steering:
Steering gear/rack and pinion assembly, power steering pump, steering column shafts and coupling.[/FONT]
Suspension:
Upper and lower control arms, upper and lower ball joints, tie rod ends and struts. Coverage under this section is afforded only after the vehicle has been driven 1500 miles from the purchase date of this agreement. [/FONT]
Labor:
The labor hours to repair or replace all parts covered under this service agreement as defined in the All-Data estimating software.[/FONT]
What is Covered (for applicable vehicles only):
Four Wheel Drive - All internally lubricated parts contained within the transfer case, all internally lubricated parts within the front differential housing, and locking hubs. Both the transfer case housing and the front differential housing are covered only if damaged by an internally lubricated part.
Turbo/Supercharger - All internal parts within the turbo/supercharger housing only. [/FONT]
Convenience Coverage:
1. Rental - Extended Auto Warranty Corp. will reimburse the customer up to $30.00 per day, for a maximum of five days, only if the labor for repairs exceeds 8 hours [published industry standard time to repair or replace the covered part(s)], on repairs covered by this contract. Downtime waiting for parts or scheduling for service is not included. Receipts will only be accepted from Licensed Rental Car Agencies.
2. 24 Hour Roadside Assistance: For assistance please call
1-800-451-0459. Coverage is as follows:
Towing Assistance - When towing is necessary, vehicle is towed to nearest service facility within 150 miles.
Battery Boost - If battery failure occurs, a jump-start will be applied to start the covered vehicle or transport you to purchase a new battery if needed.
Flat Tire Assistance - Driver will change and mount your spare, or transport you to nearest tire store for repairs.
Gasoline - Driver will provide purchaser with two gallons to get you on your way.
Lock-Out Assistance - If Your keys are locked inside of Your Vehicle, We will provide assistance in gaining entry to Your Vehicle or provide a locksmith if needed.
[/FONT]
[SIZE=-1]** Coverage purchased for an additional cost (included for all online consumers at no additional charge!) [/SIZE][/FONT]
