Corvette Steeroids for Small Block Installation 63-66 Corvette SB - Power
xplosive performance
Longwood, Fl
None right now, work on many
Corvette Steeroids - Feel The Road! Steeroids™
Offers Improved Steering Feel -
Recirculating ball steering is vague and unresponsive, especially "on center".
Control is greatly enhanced.
Steeroids Offers Quicker Ratio -Steering racks offer quicker ratios. Steeroids™ power kits yield approximately 2.5 turns lock-to-lock (~2.9 for manual).
Steeroids are the only kits with adjustable tie rod ends to prevent bump steer - keep your car grounded and avoid darty behavior by keeping your alignment (bump steer) curves in check.
Steeroids Are Lighter Weight -Compared to the stock steering system.
Steeroids Offer Bolt On Installation -Absolutely no welding, or drilling. Installs with basic hand tools in approximately 3 hours.
Stock Pump Used -Existing or readily available power steering pump and brackets can be used.
Steeroids Come As A Complete Kit -All necessary parts are included with the exception of the power steering pump.
Parts Included With Steeroids: Rack and pinion
Adapter brackets (powder coated black)
Adjustable tie rod ends (Self cleaning & lubricating, teflon lined).
U-joint assembly
Power steering hoses
Misc. fasteners (grade-8)
