- Thread starter
- #21
C
C4D
Thanks for the tip Tuna... this might be very well the case because I also noticed that the passenger door panel is loose on the right hand side and creates a very large gap between the window and the panel, this might be a sign that a connection could be loose or something moved and froze up. I just need to take the panel off and test/check the connections then try your fix with helping the window up and down.
ad
