L
lheindrich
I have some cracked fiberglass under my hood from years of neglect. My hood does not line up well and it is difficult to open the hood up after I pop the latch release and it has resulted in cracked fiberglass. I want to remove the hood and repair the fiberglass and give the underside a nice coat of flat black paint. Then I wasnt to put in new underhood insulation since the previous owner removed the insulation. I will also replace the piece of weatherstrip that goes on the back of the hood. I want to know what type materials will I need to repair the fiberglass and what type of paint should I use and should I cut out my own piece of insulation or should I buy the correct piece from a Corvette parts supplier. Once I spruce the hood up I will realign everything so this will not happen again. Thanks.
