Here’s my problem still . Any help would be good. I blew a radiator hose several weeks ago engine stopped, I changed the hose and drove home no problem. Four days later engine stopped would not start I presumed it was the Opti I replaced the cap and rotor newplugs, engine ran but missing and coughing back firing so presumed the opti was out of timing, so removed opti checked my work and reinstalled everything. So for the third time no improvement I did it again, this time I replaced the distributor with MDS iinstalled new coil and crank shaft sensor and still no start, used easy start and engine fired for shorttime dst were P0100 and pins connection under wheel were showing H64 and H65 replaced MAF, checked fuel pressure again and now have no,fuel pressure but had it before, so replaced fuel pump and filter (now have good fuel pres) but still missing, and showing still P0100 ran car around the block it appeared to have some oil sprayed from area of cyl 6-8 now could not identify where from, changed oil and filter when I removed oil cap there was water impregnated oil on cap sopresumed it was possibly a head gasket today removed all spark plugs and did compressiontest all cylinders were 150 psi removed valve cover on passenger side and waterin oil impregnated that had been there for some time also drops of clear water on valve rockers ??also some clear water in breather pipe.
Is this water condensation or possibly left over from theoriginal hose burst? Seem strange that it was clear clean water droplets andthe yellow oil gunk seems to be rather old. The oil drained was completely normal no water. There appears to be no oil in the water system. Is it possible that water has got into the MAP causing the miss, due to it be sticking? Checking the PCM circuits fromthe MAF what color is the wire location connection.
