Cranks wont start no codes
billd
Denver,CO
2001 red convertible, 1985 wht
2005 won't start. Cranks, has fuel pressure, replaced CPS, no error codes. Thank god it broke in the garage. Any suggestions?
Surprised nobody commented on this. It has to be fuel or spark. Pull off one of your plug wires and lay it close to the spark plug and crank it. If you have a spark jumping to ground it's a fuel problem. If no spark, it's ignition. This will give you a place to start looking.
Tom
Tom
I have no spark. New crank position sensor. 60 psi fuel pressure.
I've been in Arizona for awhile and not able to check in much. Did you find a fix for your problem?
Tom
