S
Sethanon
I bought 1975, about 9 months and engine dead. I was thinking of putting ia ZZ4 GM crate engine in it. Is this a good idea?
I'm all but certain that the "melonized" gear on ZZ4 's distributor will fit right onto your 68's tach-drive points distributor (shaft OD .491"). Then you can run your old tach-drive distributor with the ZZ4's OE roller cam. The ZZ4 dist gear is NOT bronze but has a treatment called "mellonized" (?sp?).68Roadster said:Thanks Roy and ALPacer,
That and finding a dist to work with my tach drive have been the two unknowns with regards to dropping a ZZ4 in place of the original engine. I'd love to do it.....
The ZZ4 is a drop in engine for (any, I think) C3. It dropped right into my '80.Stallion said:Can you/is it popular to modify a crate engine like a ZZ4? I would love to have one too, but I don't want to be stuck at a certain amount of power, provided I would want more in the future.
I don't know if you stock exhaust manifolds will work or not, but why not just pop on a set of Hooker headers or something? Leave all the old stuff on the engine or part out the manifolds as well. I put mine up on eBay and sold 'em with no problem!68Roadster said:Does anyone know if the stock exhaust manifolds will bolt to these crate motors
ZZ4 comes with a flexplate for auto trans ... it does not come with flywheel for manual trans. ZZ4's newer crank (like all other later one-piece seal cranks) has different bolt pattern than your old (2-piece seal) crank. ZZ4's newer crank will not bolt up to your old flywheel. ZZ4 will require a new flywheel. ZZ4 will bolt up to your old bellhousing & trans. ZZ4 also comes with "long" legged water pump ... your old motor has a "short" pump ... you'll have to swap in order to align pulleys. If & when you do the ZZ4 thing ... and don't use its HEI, I'd like first shot at buying it from you ... keep me in mind.68Roadster said:Jack,
Thanks for all the info.
Right now I'm under the back end re-doing the diff, shocks, bushings, re-painting the frame, etc.....starting to feel like a frame off.......the crate motor/pickling the original is probably a year or so off but I like the ZZ4 option. Does it mate well with the original bellhousing/M20 4 speed that I currently have??
