firstgear
- Joined
- Oct 11, 2003
- Messages
- 1,895
- Location
- Norwalk, Ohio
- Corvette
- 15 Z06, 01 Vert, 63 SWC & 60 ALL RED
I was adjusting my front suspension for the caster, camber and toe in and found a way to bugger up the threads on the upper a-arm attachment point. It is so buggered up that the first three threads are a total mess and I can't get a tap started.
I can't go in the other way because when the part was fabricated the threaded holes at each end were started from the ends and not through.
I almost feel if there was a thread chaser that I could collapse and insert past the bad section that I could then thread it back out and cut the threads cleanly again.
Anyone got any ideas on what could be done????
regards, Herb
regards, Herb
