AussieCorvetteNut
Ok, I know this topic has been flogged to death, but from what I see, the postings are a few years old, meaning there may or may not be new technology out there.
My issue is that I am starting the process of removing my matching numbers engine and DNE 4+3, and rebuilding the engine and boat anchoring the 4+3.
i have spent that last couple of days starting the process of disassembly and tagging wiring harness connections, I am getting ready to pull the transmission, only have two torque arm bolts and the four on the bell housing and the trans is out. The engine is next.
while removing the inspection plate on the bell housing, I noticed a drop of coolant where it shouldn't have been. My guess is maybe a rear welch plug, although the others in the block seem fine, old, but fine. The only other thing it could be is the inlet manifold.
Here is my issue, my engine shop will want to know induction requirements for recommending the appropriate cam, intake valve train etc, set up.
Question is, as there aren't too many replacement crossfire intake manifolds on the market, in fact from what I can see the last one Renegade has just shut up shop and Ecklers and Summit have the last few in stock...what do I use? It is 2015, what upgrades are there?
I would like to rebuild the engine, enhance it a little and use the TBI set up, I just want a cruiser that is more reliable and just a little better than it was when it was new. With no crossfire intakes on the market, I only have a few options left.
Edelbrock do a great 4V bolt on injection system, but I would need to go back to an old school looking manifold. The system is plug and play and can learn as it burns.
Renegade have a crossfire intake that is the same as the OEM with improvements, but I know by the time I get around to rebuilding this L83, that option will be out.
Edelbrock also have a Ram Air type, but it may not fit under the 84 bonnet.
I could put a TPI on it, but then I think I should change the heads....besides that upgrade has been done before. I don't really like seeing crossfire injection on the fender panels and seeing TPI. TPI is great though don't get me wrong.
i would love to keep it stock looking but the options are drying up, I like the ram air Edelbrock set up, but it may not fit, I wouldn't want to install the TPI unless I changed the heads.
i know some fellas have got some serious power out of tweaking their TBI's, my issue is that if my intake has water jacket issues, then to replace it I would need to install a second hand crossfire intake...bit like putting brand new tyres on wheels that are rusted out.
I dunno which way to go, would appreciate any help.
cheers
Tony
cheers
Tony
