HI there,
Actually, unless your 1571 is a C, for current code, this is classified as normal, and does not have anything to do with your cruise control.
What really has been seen is misadjusted brake switches underneath the dash board, creating automatic shut off of the cruise control.
If you would remove the lower hush panel, you will see 2 brake switches, located in front of the brake pedal, on a metal bracket.
If you push these 2 switches forward, they will click a few times.
Then, with only 2 fingers, pull up on the brake pedal.
This will adjust your cruise control switch, and then take it for a test drive, and let us know what you come up with.
My guess, if the adjustment is dont correctly, your cruise will work fine from this moment on.
Allthebest, and please keep us posted, c4c5
