Custom chip for my 85 vette
  • Thread starter Thread starter selkirk24
S
selkirk24
Hey guys, need some help. The previous owner installed 30lb injectors in it. The problem I am having is that the car is running rich, especially at idle. My friend has a scanning tool and the O2 sensor says it is running rich. I am assuming that because he put the bigger injectors in, the ECM can not compensate for the greater fuel flow.
I am hoping that someone can either burn me a chip to adjust for the greater flow or direct me to someone who could do it.
Any help would be greatly appreciated.
Selkirk24
You might want to look at the "custom chip" trace. It should explain all,
bottom line check out http://www.fastchip.com/index.htm.
Nice to hear from another 85 owner.
BTW, I replaced my FIs with 24# and put in an adjustable regulator. It would be nice to find the best setup, which TB (48-52) to size FI (24-30) to heads (stock, performer).
I read several articles describing mods and which are good or bad. For example a large TB would be a waste of money unless you have other mods.
Before I order my custom chip, I am going to validate my final set-up.... trace to follow.
