O
oldvet
Took my dash unit out today and took it apart. The only thing I found wrong was that three of the halogen bulbs were burnt out. The tutorial mentioned earlier suggests replacing the 882 halogen bulbs with 194s. I looked at bulbs in 5 parts stores today and all the 194s have an incompatible base with 882s.
So!!!, I bit the bullet and bought the 882s. You can see that they get very hot due to the discoloration and the mounting area on the board. All my solder joints looked to be iin fine shape.
Will let you know how it works after I reinstall it.
It is a ***** to get out. The metal clips are on the back of the plugs. It helps to take out the two screws above it that hold the glare shield down to allow a little give. I also removed the teltale unit in the center.
Glad to hear you got it. Took mind off so many times, I can do it in 10 minutes.
