macx
Planning some mild mostly top end engine and drivetrain upgrades to my 81 so I can take some longer trips after I retire and get good mileage while still improving mid range throttle response.
The one bit of information I can't find is the deck to piston clearance on a stock L81 engine.
I can calculate it, but I have read somewhat varying information on piston compression height, as well as installed head gasket thickness.
From what I read, there's not much in the way of a quench area on top of the stock pistons, let alone in the comb chamber. I had hoped to avoid pulling the engine and changing pistons because of the work and cost involved with parts & machining, and because the shortblock is in decent operating condition, but fear I won't have any decent quench area otherwise which is necessary for detonation control so I can up the compression about 3/4 of a point and still run 87 octane.
I will be going with aftermarket Vortec style heads but will probly need pistons with matching quench area.
Thanks!
Thanks!
