It's time for our annual Map Rally! We will give you a map with a dozen or so points-of-interest marked on it, and you will have 30 minutes to determine the shortest route to visit them all, and return to the start. Then you go drive your route, and we will measure the mileage you took, according to your car's odometer. We don't know exactly the route you will take, but it will probably all be in rural Parker County.
We had three Corvettes entered in our last rally, with one of them coming in fourth in Novice Class.
Registration will be at Holt FIAT of Fort Worth, 400 W Loop 820 S, Fort Worth, TX 76108, beginning at 9:00am. Take the White Settlement Rd exit from I-820. For your odometer calibration run, you will drive from there to Logan's Roadhouse in Weatherford, where you will receive your map, and determine your route.
When you are ready, drive to the checkpoint in the Logan's Roadhouse parking lot to be timed out. You will have several hours (time to be determined) to visit all the identified points and return to Logan's parking lot, to be timed in, and your mileage recorded. After everyone has returned, we will award trophies for the shortest distance traveled.
Note: GPS and other electronic aids are allowed on course, but not inside Logan's Roadhouse while you are working on your map.
Don't miss this one! The map procedure is a little easier than past years, and you will be driving on roads new to most of us. Preregister now at http://www.msreg.com/DMR16msr .
Join us!
Join us!
