Help! differential oil leak
liverpool england
white 69 spec. convertor lockup on manual switch
just noticed i have an oil leak from the left hand differential output shaft. is it possible to replace the seal without removing the diff ?
I've looked at my '81 and if there is I cant figure it out...;shrug
there are clips retaining the stub shaft in the rear end so the back cover needs to come off just as easy to drop the whole thing steve
