iambutch1
- Joined
- Nov 12, 2001
- Messages
- 16
- Location
- West Salem, Ohio USA
- Corvette
- 1972 Corvette rebuild complete and driving
I see this topic never goes away but I haven't seen this answer yet. I have a 1984 vette that I have retuilt. The cluster has been working just fine until last week. My battery was dead so I jump started it. After I got the car started the cluster is now weird.
When you first turn the ignition on the cluster goes through its check and everything cycles fine and looks good. But after it checks itself the speedometer goes to 14 mph and the tach reads nothing. After the car is started the tach and speedometer remains the same, 14 mph and nothing on the tach. The upper portion of the cluster works as it reads oil pressure and temp as well as reflecte the gas level. I would think that the cluster was bad if I didn't see the cluster do its diagonistic.
I figure that there was a voltage surge when I jumped it but I don't know where to look first. I have the cluster out and ther appears to be no burned segments in the circuit boards. I have ordered a tach filter hoping that this might be the problem.
Any suggestions?
Mike
Any suggestions?
Mike
