Help! ... I pulled the distributor out of my 327/300. Before I pulled it out:I left the rotor pointing straight ahead and marked the firewall. As I pulled the distributor out the rotor rotated counterclock wise about 20 degrees and marked that spot. So far so good.. I go to put the distributor in. I face the rotor where it came out. The rotor then rotates clockwise 20 degrees and goes in ... but does not seat! ( Although it is facing the direction it should )
I look at the oil pump notch in the engine and it seems to be 20 degrees further. To verify this I put the distributor in with the rotor facing the direction where it originally sat ... as it should during installing the rotor rotates clockwise and seats perfectly. The problem is the rotor is facing 20 degrees further clockwise then when it originally came out???
Now what ???? ... I haven't tryed starting the engine yet.
