Maybe I can save you some trouble.
HEI springs are too long and will not return your mechanical advance weights to the idle position reliably.
Mr. Gasket advance kits for points distributors contain three sets of springs with different tension levels: Super Wimpy, Weak Suck, and Almost Okay. These kits also contain weights that are shaped incorrectly to use with stock springs. Don't waste your money. These spring/weight combos all come in before 800 rpm.
GM no longer sells any advance springs for points distributors.
Chevy passenger car distributors with used springs are common at swap meets and on eBay. They're a cheap source of used parts, but they usually contain springs that are too stiff to use in pairs to create a performance advance curve. You can, however, combine one passenger car stiff spring with one aftermarket Almost Okay tension spring to get a pretty good curve.
I can buy a "reproduction" of the '58 - '61 FI distributor advance spring for $3 each from my FI parts wholesaler. But, it doesn't produce the stock advance curve for that FI distributor or even a good performance curve.
I'm about to test a spring design that should have the correct length and tension to substitute for the stock '64-5 FI distributor advance springs. If it tests okay, I should be able to sell them in pairs for $5 including postage within a month or two. We'll see how it goes.
