Dad
- Joined
- Nov 18, 2001
- Messages
- 611
- Location
- West Unity OH
- Corvette
- 15Gray/8sp 72Blk/Blk4Spd 64Red/Red/Wht4spd
Question, the standard radials (speed rated) that I replaced the Run Flats with make a big difference in the way it rides and the noise level is great. I want to jack the air pressure to the right pressure to get even tread wear. The seller and the installer want me to run what it says on the door. That's nuts, when you consider the side walls are not as heavy. Is the tire on the Z06 run at the same air pressure as the run flats? How can you tell when you have the right pressure in a tire before you see a bad wear pattern?
:confused
:confused
