Do I have a problem here?
Edmond
Louisiana
2003 Z06
I went outside this evening to shut the windows on the Vette'. I don't see the need to start the car just to shut the windows so I just switched the key to the on position to shut the windows.
I noticed that when I was shutting the windows; the tach was going way up to 2600+
I don't think that's normal is it? :confused
Nope, that does not sound normal - at least to me... I never the see the tach moving when the key is at ON position. I wonder what may be doing this??? I will check this when I go home today.
Was the tach only registering when you were actually moving the windows? There's a filter on the line from the distributor to the tach to help weed out unwanted electrical "noise"; possibly this filter is DOA? Or maybe not grounded to the block any longer?
Just a guess...
[RICHR]
I am not sure if my tach moves when I turn the key on or not. If it does it will light up then go away really quick. It is odd that I dont know for sure, I will check and let ya know.
Craig
Mine will jump all they way up then come back down to 0 like the spedo and the other gauges. Does it read out ok when your driving the car?
Justin
Justin
Yes, it reads okay when I'm driving.
Justin
mine does the same thing
