gmjunkie
If you look in the photo of my Z-51,you can see it!! That metal ring around it ,on the back side and it has a clip that go's through the rubber boot that clips around the PCV valve!! It's a purdy heavy wire that go's to the Ground!!How is this wire attached to the PCV? Is it just a clip that goes around it or what? I know I did not have anything dircectly attached to the PVC. On the surface this makes very little or no sense. If you find out what this is or for I would be interested in knowing this :confused
Have you got pictures of this or not?
Junk, he da Man![]()
Thanks,
Bill![]()
. I found out how bad this oil in the intake problem was when I changed my heads. The intake ports, and the combustion chambers were coated with oil. So I searched for a solution and found it on the Nissan forums. The import guys have been dealing with this problem for years, and is amplified using a turbo or supercharger setup. Basically what I found out was oil added to the fuel for combustion will reduce your overall octane content not even considering the mess inside the heads. If you have high compression, you run a risk of detonation. I make sure I keep my intake very clean of oil and also relieve oil from the lifters back to the main oil gallery alot faster than stock to offset other parts that may need oil, because I could, I had the heads off, so I drilled holes into the retainers to drain all the oil that sits up in the retainers pooling there. Every little bit helps. Some may even get unspent oil in the exhaust and coat the back of the car depending on how bad the problem is. How's your catylitic converter look if you have one?
