A
Annivette
What are the major differences between the L48 and the L88 engines? Is there any noticible differences or just hp?
Annivette said:What are the major differences between the L48 and the L88 engines? Is there any noticible differences or just hp?
What are the major differences between the L48 and L82 engines?
Includes larger ports, longer duration & higher lift cam, larger intake & exhaust (2.02"/1.60") valves with higher lift, pushrod guideplates, pushrods with steel inserts on rocker arm ends aluminum impact extruded pistons (flat/notched), moly rings, forged steel crankshaft & 4-bolt main bearing caps, higher capacity starter, and finned aluminum rocker covers.
78SilvAnniv said:What are you cluless about, we'd love to help...
Heidi![]()
