2268irma
New member
Neither cable would open my drivers door I removed the inner panel and found the plastic housing & both cables not hooked to latch. Can any one show me where they go and how the plastic housing is held to the latch. Thanks Bob
I can't help you with your question though. Hopefully someone here will be able to chime in with the answer. You know, I've never tried opening the doors with the cable, I ought to try it some time in case I'm ever caught inside with a power failure.Nice car Tom just sold mine I loved the color I just bought a black convertible. The coupe was great but nothing beats a convertible especially in Arizona don't put the top up unless its over 100 or below 60. I ended up buying a complete latch assy. off the forum. It would have been a lot cheaper and better to put a key switch in the door. I know someone who broke the door window so he could get the hood open the cables didn't work. All the Corvettes I( owned in the last 60 years I never had a dead battery till this one it won't last a month not being run. Take care and check those cables and that key lock in rear. I pulled mine out and wrapped it in duct tape put it back in and put tape over the key hole it keeps it clean and always turns. BobFirst off "Welcome" to CAC is in order.I can't help you with your question though. Hopefully someone here will be able to chime in with the answer. You know, I've never tried opening the doors with the cable, I ought to try it some time in case I'm ever caught inside with a power failure.
