Tims93
I've removed the door panel and have the regulator exposed and I can see two nuts that look like they are on bolts that run through the glass. The window is in the up position. If I remove these two nuts do the bolts push out the other side of the glass?and then does the glass just lift out or is there more to it? I'm replacing the window motor and I don't want to break the glass by making a stupid move. Thanks in advance for any info and have a Happy Thanksgiving. Take Care, Tim (car is a 93 coupe)
