C
CAJUN C4
My 95' has a slight door(s) leak and I don't think it's the window gasket or the window needing adjustment.I can see on the door panels about 6 inches or so from the front of the door panel where water has been running down the side of the pane and ending up on the front of the door sill is where I find water.I believe it's the door gasket? The problem is I can't see it to tell with the door closed.
Anyone experience this?
Thanx
Thanx
