V
vetteengnr
I am having an extreme problem with my driver door. It won't open!!
original problem:
The key lock on the outside of the door has significant play and doesn't seem to activate the mechanism except for a very small click. The knob on the inside of the door has decent pull on the locking mechanism doesn't really unlock the door.
now:
I was been able to remove the door panel and look at the lock mechanism a little better. Once I put the lock knob back on the inside of the door, IT UNLOCKED!!! I was so pleased I sat and clicked the lock back and forth and have a door that worked. It would lock and unlock freely from inside the door. Unfortunately I tried to work the key on the outside of the door. Bad mistake. It provided just enough torque to relock the door and now the inside lock doesn't seem to be providing enough power to unlock the door again. Once again I am stuck.
Has anyone had this problem before??
I saw that mid america sells new lock tumblers for the outside lock. Are these a difficult install? I'm going to try and get the door open again tonight. Is it possible to pull of the outer (metal) panel from the door to get to the lock mechanism without having the door open? It is pretty obvious that I'm not able to steal a C3 I can't defeat the lock!!
Any help or advice on the door locks is greatly appreciated.
Brad
original problem:
now:
Brad
