V
vetteengnr
I have seen quite a lot of posts about locks and good advice for lock problems that quite a few of us seem to be having.
I have two problems that haven't really been adressed.
1) The outer door lock turns freely and does not put torque to the lock mechanism. I know I need to replace this...Here's the problem: I purchased some fishing pliers and can grab on the clip, it just won't move. Do I need to just pull harder? I feel like I could screw up the fiberglass if I pull too hard.
2) I also have problems with the outside handle. The spring that is attached to the handle is no longer attached. Does anyone have a picture of where the spring for the outer handle attaches to the control rod? If I order a new door handle does it come with the spring attached and a new rod?
Thanks for advice!!!!!
