Jim Z06
Have a '02 Z06 that the driver door will not unlock with FOB or by pressing unlock button on inside of door. It does lock by using either FOB or lock button on door. It also unlocks manually with the key. I have read on other threads that it is likely the relay in the door control module. Have also read that it might be the actuator. I'm thinking the actuator is ok because the door locks fine. Any opinions before I take the door apart. Thanks, Jim
