came on briefly on Saturday.
I was sitting on post at the shop waiting for a bay to open up. Backed into a spot and opened the windows. Saw the "reduced engine power" and thought that was strange, never seen it before. Then the driver side door controls wouldn't work, none of them would.
Tried the passenger side controls and those worked.
Tried starting the car and it started fine. Decided to head home at that point, driver side controls still would not work and the doors did not auto lock like they usually do at 10mph.
Also noticed that oil and water temperatures were high. Oil was 220 and water was 230. Figured that thermal inertia had them rising after I stopped the car and there was no fan or air forced underneath to cool it.
After driving for about 5 minutes, the temps dropped back to normal.
From my reading, it seems that the main culprits could be:
weak battery
alternator
G101 ground
G102 ground
Those are all pretty simple to check.
Any other suggestions?
I've also read that low coolant could possibly cause this. Is this true?
weak battery
alternator
G101 ground
G102 ground
