D
dramo1
i am getting conflicting info..around town should i be driving my 86 coupe in D or in D with the square around it..i assume that is overdrive
MBDiagMan said:This will depend on your driving style. If you don't drive your Vette like I drive mine then you can ease around town on the OD position and it will take advantage of those stretches where it can use the OD. To fill in the answer, my Vette only has two throttle settings, foot fully off or foot fully on the throttle.
If you are a spirited driver and don't get up to a steady speed in town then D should work okay. Keep the trans serviced.
Good luck,
dramo1 said:are places like lee myles ok for tranny service..or are they the jiffy lube of trannys
Vettefan87 said:Keep it in Drive for stop/go traffic. When you get out on the road put it in OD, it is very hard for the tranny to go in, and out of OD, and do not go up a incline in OD at a very low speed around 40 mphish.
