Driver Info Panel
  • Thread starter Thread starter LOUVETTE
L
LOUVETTE
DOES THE DRIVER INFORMATION PANEL HAVE BULBS BEHIND IT .........LIKE A BULB FOR PARKING BRAKE OR ANOTHER BULB FOR THE CHECK ENGINE LIGHT ECT. OR IS IT SOME TYPE OF CIRCUIT BOARD....WAS WONDERING CAUSE I DONT HAVE A ANTI LOCK BRAKE LIGHT COMMING ON WHEN I FIRST TURN ON THE IGNITION LIKE IT IS SUPOSED TO BEFORE GOING OUT.....WAS HOPING ITS JUST A BULB........ANYONE HELP............THANKS
ALSO WHAT DIFFERENT LIGHTS ARE SUPOSED TO COME ON......
LIKE IF ALL THE LIGHTS WERE LIT UP WHAT WOULD THEY BE EVEN IF THEY GO OFF AFTER STARTING LIKE CHECK ENGINE SOON.....THANKS
Hey Lou....
first off turn the caps lock key off....folks think you are shouting!
Second...yes there are bulbs behind the panel. Remove the center piece and then remove the panel cover to access the bulbs...
reply
thanks ......no never shout just have habbit of using caps.....do you know what all possible light combinations are ther under the cover....i know of brake/check engine/low coolant/door ajar/think fasten seat belts//must be more
Indicator's
Varies from year to year
Rear Hatch ( coupe )
E-brake ( ALL )
Check engine ( ALL )
Batt ( ALL )
Low Coolant ( ALL )
ABS (86 up)
ABS ACTIVE 88 up
Service LPTWS ( 88&up option)
Low pressure ( LPTWS )( 88&up option)
Key on.. the check engine,Batt & ABS will light
And the ( if you have the option) LPTWS
Low coolant will not..until you are LOW ( have to check this)
This is off the top of my head
Vig!
