bilhickok
New member
Found a fix for drooping sun visor 1980 corvette
1. Pull clip off shaft of visor
2. Pull out shaft and plastic bushing
3. Bushing splits into two pieces,like a clamshell
4. cut the tip off the finger of a thin rubber glove and fashion into a small rectangle of rubber
5. Place the rubber into one side of the bushing
6. Put the bushing together around the visor shaft
7. Replace bushing and shaft into holder, replace clip.
8. Rubber creates needed friction to hold visor up. Be sure to use thin rubber or bushing/shaft assembly will be to big to get back into holder.
