Dropping the transmission
I use this "saddle" to support the engine - the base is a piece of 2x6, and the sides are 1x6 that sit on top of the base and are attached with 3"-long drywall screws driven up from the bottom. It snuggles up on each side of the oil pan, the sides are about an inch taller than the depth of the pan, and it supports the engine's weight on the pan rail, not on the pan - no marks, no dents. The notch on one side is for clearance at the "bump" for the dipstick tube.
When you install the new throwout bearing, make sure you do it correctly (the design allows it to be done wrong); the ends of the clutch fork AND the ends of the flat spring BOTH go inside the groove on the bearing; if you put it on with the "curls" at the end of the fork capturing the flange at the rear of the bearing, you won't be able to get the clutch adjusted. All three sides of the groove need a light coating of gray moly grease, same thing on the inside diameter of the bearing and in the groove in there, plus the recess in the clutch fork where the pivot ball rides.
John, the throwout bearing is what is moved when the clutch is pressed in? It pushes on the diaphram spring? Or is it the bearing in the rear of the clutch assembly from the crank?
The bearing/bushing pressed in the back of the crank is the pilot bearing/bushing.
You are correct about the throwout bearing.
Stallion said:
Okay, now it's time to take out the transmission (to get to the clutch). Just to go over it again, I un-bolt from the rear mount, then the mount on the bell housing (all the while having the engine supported on a stand/jack). Then twist the spindle out of the housing back, then slip the transmission down.
But, I know I'll have a floor jack under the transmission to take her out, but I'm having a hard time being able to menouver (sp?) the tranny to snake it out of the car. What do you think?
And another thing, I imagine that I should drain the transmission from its lube, right? Is the plug on the passenger's side and is it a square bolt (four corners)?
Thanks! :D
Stallion
How's it going??? did you get the tranny out??? curious minds want to know ;)
Bud
Yepp, I dropped the tranny! Now it's on to the bell housing and finding the problem. :) I'm going to get a whole new clutch kit (pressure plate, throwout bearing, clutch disc, etc.) and replace it. But I'm just so scared that I will do all that and she still won't work. :(
The weather got really cold in the last month and, well, my garage isn't heated. But now that it's warming up I'll be able to tackle this more! :)
