Bwmurph
Hello All,
I'm still in the proicess of re-building the dual quads on my '59. THis is taking FOREVER !! Doesn't help that I have to go out of town for work for days at a time, but that's another story....
Anyway, the carbs are back together; didn't have too many problems, but want to run a few things by anyone who has done this and may have some helpful hints:
While doing the primary (rear) carb I lost the little spring-type clip that holds the metering rods in place. Couldn't find it anywhere, but am sure it is on the shop floor somewhere. Anyway, the metering rods won't stay in place without and I couldn't (after several hours of trying) fashion a suitable replacement. Got the bright idea of simply crimping (very carefully) the rounded ends of the metering rods tight around the metering rod hangar. Seems to work fine and doesn't bind at all, but am wondering if this is going to give me problems down the road.
Have cleaned the intake manifold with parts cleaner, but it didn't shine up too well. Just now hit it with a soft wire brush on a drill and it shines up nicely (guess I'll have to get a Dremel tool or similar to get in to all the nooks and crannies. Is there a polish you can put on the bare aluminum to keep it nice and shiny ? Afraid that "Mothers" aluminum polish won't hold up to the heat.
THis set-up is going on an early crate motor (350 CID/300 HP) that has the center bolt valve covers. I have a fairly nice set of early aluminum valve covers and saw in the GMPP book that they have an adapter kit so you can use the early style valve covers with the center bolt heads. Has anyone used this adapter kit, and how does it work out ?
Thanks for any and all replys (If I can figure out how to post pictures here I'll put some together and get themon here at some point),
Bernie O.
Bernie O.
