S
SMKN97GP
is changing the rear diff fluid hard on an 81? there isnt a nice plug on the pumpkin somewhere that i can drain it out of right? mostlikely im gonna have to take off the cover, if thats the case from the look of the chiltons manual there is a big piece over the cover like a giant brace spanning across the rear end, is that a PITA to remove? it looks like it would be alot bigger job than say changing the rear diff fluid on an 87 camaro?
second, next tuesday im going to my buddys shop to do some work and we are doign exhaust stuff. if i remove my cat, there should be no negative effects right? because the 02 sensor is before the cat. and if i wanted to go true dual, would it be ok to have just one 02 sensor on the ride downstream and none on the left? i know some of you other 81 guys out there have heavily modifiee exhaust so im wondering how you did it.
