allcoupedup
Looks like you have flat tops. Unless your cylinder head chambers are small or your block has been decked your comrpession ratio might be different than stock. LT1 and 30-30 like higher compression motors. You should measure and determine your actual static compression ratio so that you do not have another engine/cam mismatch. Measure your piston/deck height and your cylinder head combustion chamber volume and select a head gasket to get you between 10.0:1 and 10.5:1. If you cant get in this range you can change/modify the pistons/heads. If you get below 9.5:1 you might think about using a different cam.
Regards,
brian
Regards,
brian
