goingballistic
First off thanks to all the people on this board that helped me get this motor to the point it's at, without your help ( and you know who you are) this would have been a lot more painful.
My won and I started this project two years ago, so it's a long time coming. Started with a old 350 block from a '74 Nova and built from the ground up.
Two days of testing on the dyno, painful but I would recommend a dyno test for anyone who builds from the ground up to work the kinks out before installation.
Problems encountered during the test:
1) Fuel flow was too small with an Edelbrock 750 CFM Carb, ended up with a Demon. Edelbrock has a convulated air flow through the secondaries and starved the horse power. 750 Demon got me where I wanted to be as there is no restrictions in air flow through the throats.
2) Roller rockers needed to be torqued to 1/2 turn tight NOT a 1/4 turn tight to set the rockers correctly, one poped, we caught it before it did any damage.
3) Two piece timing covers are crap, don't use them. ****ed three quarts of oil out the front, had to change to a one piecem worked fine after that. The two piece doesn't hold under vibration, don't use them.
4) Oil fliter needs to be tight.................ooyyyy. Oil pressure on the 10th run dropped to 2PSI my blood pressure went the other way, thank god we caught this one before we did any damage. If this was not on the dyno, it would have blown the motor.
All in all it was a great way to break in, money well spent and saved my engine. Ready for drop in now, headers on back order, wish I would have had them before the dyno but couldn't wait any longer. The headers we tested with were only 1 3/8, engine is spec'd for 1 7/8 so I expect a little more power with the right headers.
Final results: 425HP with 472 ft lbs of torque ! Yikes...........now I need a new diff ratio............my wife is gonna kill me...
Pic of the motor on the dyno.......
Link to us doing the rebuild
http://www.supermotors.org/vehicles/registry/detail.php?id=5167&s=17984#content
Cheers.
Cheers.
