bucket
whats the point if you cant adjust anything...:confused
With the right equipment
Ostrich 2.0 : The New Breed [OSTRICH_2] - $175.00 : Moates.Net
you can adjust anything set by the factory; in real time while you are driving or on the dyno..
How do you think guys do custom tunes on modified engines.
$175 , a old laptop and some free software gives you access to the stock computer (before '94 ) Later LT1 cars can be done using different but similar setup
You as a uneducated tuner at home can delete VATS , delete EGR ,change fan temps , change convertor lockup speed ,idle speed, anything.
You can change anything to do with the running of the engine but it is a steep learning curve best left to experts unless you have a lot of learning time.
I'm five years in and still using training wheels.
Cheaper alternative , but requires chip adapter for ECM and removing the chip from the car, downloading tune and replacing
BURN2 Chip Programmer [BURN2] - $85.00 : Moates.Net
G1 Memory Adapter: TPI ETC.. [G1] - $35.00 : Moates.Net
thats all very nice stuff. but that just isnt what im asking.
In a 92 , they still have to reprogramme the removible memcal in the computer somehow because the flash memory didnt come out until 94kind of like what you are saying except with a stock corvette.
you need gear as stated abovewhats the point if you cant adjust anything...:confused
Vetteoz answered you correctly, a dyno tuner will be using that type of gear and you are hoping the dyno guys of choice have experience with various makes models of ecm's. The only way to tune a computer controlled car is with that type of equipment and reprogramming the eprom in the ecm.....thats all very nice stuff. but that just isnt what im asking..in the mean time the dyno tunner guy filled me in..
they will optimize the air fuel mixture and wot etc shift points and lock up and stuff like that.. kind of like what you are saying except with a stock corvette. thanx for the response
Having a totally stock motor dyno tuned might provide some hp (don't expect the moon) gains, but the biggest improvements would be if they tuned Closed Loop (for typical street driving) and not just WOT.
the guys working on my car are the guys the dealers take their new corvettes to for service..they do total restoration of any year corvette...they work on nothing but corvettes..i am going to have faith that they know what to do..they will dyno tune my 18 year old baby and restore the settings to factory specs..and make sure that it is being all it can be....:cool
they did a check up and advised me what i needed, in the way of maintenance and recommended various treatments..![]()
I've got the type of equipment that requires removing the flash IC from the ECM, and using a programer to erase and write new tunes.
I'm a good 3-4 years in, and still have barely scratched the surface. I imagine that it is much easier on stock motors. I'm sure there are proven adjusments that all tuners make. I know all motors are different, but on all stock applications, the proven techniques will get close.
On a custom application, the gloves are off. What I thought my motor needed was exactly opposite of what I was giving it. What a viscious circle.
So what did they recommend for your 18 year old LT1
GM 4 bolt studded block, callies crank, compstar rods, srp 16cc inverted dish, 236/242@50 600/600+ lift h.r. billet, AFR 190 comp. port (older ones), mini ram (ported and matched), 58 tb. 36# inj. cloyes, canton pan, w/pump gas pulled 537chp 517ctq. (without a totally tweaked afr)...................
tell me about your 396
C6 Z06's eat your heart out.
Hey, Bucket, not to hijack this thread, but if you search the Internet, Street Thunder Magazine, did a LT1 396 build and it made 550hp and i think close to 500 ft-lbs of torque with a torque curve as flat as a table top. Sweet!!! C6 Z06's eat your heart out.
No,Sh*t!! :L:L:L
Man what you guys don't know about the LS7 won't hurt you.
in car pics.
I won't even both asking if "Street Thunder's" engine's power rating was SAE Net or if the engine would pass emissions certification.
