E4ME fuel mixture adjustment range??
LannyL81
Oro Valley, AZ USA
81 White/Cinnabar, 96 CE LT4 sil/blk
Okay, the 81 manual says to adjust the fuel mixture solenoid for 3/32" travel. The tool kit I got to work on the E4ME carb says to adjust the travel for 4/32"....which is correct or is there yet another number or source??
Thanks,
LannyL81
It should work either way. Regardless, you may have to adjust the lean and rich stops once it is assembled, installed, and you are tuning it.
Thanks,
LannyL81
4/32" is correct
