(snip)
So why did they change the suspension geometry in 88, if the earlier setup yielded better performance?
The change in the front was mainly to optimize handling and braking performace during ABS braking on split-mu surfaces.
What I ment Hib, by "more rounded choice", is that the SBC and the 4+3 are not exactly track friendly compared to the LT/ZF6, but as you suggested a swap would fix that.
??I would not characterize the small block-Chevy as "not track friendly". Also, The "LT" IS a small-block Chevy. I agree that the Doug Nash is a POS transmission for track use.
A LT1 or LT4/ZF6 swap should be a straight forward swap, I would think.
Well....it depends on your definition of "straight forward".
A earlier C4 would obviously benefit from the later wheels as you can get performance rubber for them, easier. That and fit bigger brakes. Oh, crap the gears in my brain are turning again.
The brake issue is significant.
Could with aftermarket suspension components a later C4 be brought UP to earlier C4 specs.?
I don't understand the question...are you asking if a late C4 can be backdated or retrofitted with the early parts or are you asking of a late C4 can be modified such that it's handing performance mimics that of an 84-87?
When I get to looking into something I want to know everything, just the way I am. Heck, I read Dave McCellans book Corvette From the Inside. While being a good book and I learned a lot it left me with even more questions. He should have provided more technical details than he did. Stupid Lloyd Reuss and his darn targa top. Dave had a drawing of his proposed C4 structure in the book, and it looked in many ways not unlike the C5 minus the T roof of course. Could have had a stiffer car but no we had to change things and then not have enough time to make changes to compensate. Management still STINKS.
The C4 structure is terrible. This is why, back in the C4 era, "harness bars" were such a useful mod to a C4. Even with shitloads of aftermarket parts, unless you put a roll cage in the car, a C4 will never have the handling at the limit like a C5.
The folks don't understand that when you have a stock C4 structure and you increase the cars roll stiffness and lateral grip beyond that of OE Z51 levels, you begin to bend the structure with cornering loads. Once you do that, at the limit, the car gets less predictable on the track. The C4 coupe structure was a leading edge design for the late 70s but Ruess wanting that targa bodystyle was a major FUBAR. I know the retired-GM guy who was first to cut the T-bar out of one of the early C4 protos. I also know the retired-GM guy who did most of the test driving back then. He told me when they began to test that car, it's handling was quite a bit worse than that of the existing C3. It wasn't until they added those big side rails to the car's frame and bolted the roof in place that the handing got better than C3.
Lastly, this discussion is not to say you can't use a C4 for track day event, but it is to say that if you really want to go fast on a road course and you're skills are such that you really drive the car to it's limits, a C5 is far better choice.
