My Easy Entry does not work I reset the fob. Checked all the fuses everything else works except easy entry and memory seat. I have a 1998 C5 corvette. Can anybody give me there ideas on what else to check.:thanks:
BruceJ
OK, I will ask these questions first.
Did it ever work for you?
If not, have you selected Easy Entry ON from the DIC options?
Do you have a telescoping steering wheel?
Do all your other Memory settings work? Mirrors etc.?
Answer these questions but I think I already know the problem.
OK, pull your DIC codes and let's start from there.
Memory for the mirrors is in each door module and the seat Memory us in the seat module.
After you pull and record your codes, disconnect the battery for several minutes and then reconnect it to see if the electronics just need rebooting.
