ECM code clearing
  • Thread starter Thread starter vipereater
I'm not sure if you're asking how to clear the codes or if you're asking if you should clear the codes or if you want to know if other owners clear their codes on a regular basis. Could you clarify?
Have other owners cleared the codes and how did the car react? I've never cleared before but I'm about to do so. I have knowledge of how to clear. Please advise.
Thanks,
Vipereater
As far as clearing the codes in the ECM you can with no problems but remember if the fault is still present the code will return either in history or active. Even after you repair the fault you still need to clear the code or after about 25-35 ignition cycles if the fault has not returned the ECM should clear itself. Be glad that the C5 has the option for you to clear troubles because with other OBD II
systems you need a scanner just to clear the codes to get the check engine light to go out. Hope this helps:beer
