B
bohms
NEED HELP!!!!Driving last night a little road lice (Honda all japped out) got on it next to me and I needless to say BLEW the rice off of him... Any way I ran it hard over 100mph.. After I backed off I noticed in the digital display on cool said 142 the analog read normal alittle above 1/2 way.. About 5min later the check eng light came on. The car seem to run normal just stuck at 142. The next day even cold the dig still read 142 and eng light was still on and the fans were running (no a/c). Again the car ran normal. I popped the hood and found the belt 1/2 gone and a peice of it near the fans. I pulled the codes off the ECM they were 15 (Coolant sensor circuit low) and 28 (Quad driver module number 3) I figered the sensor was bad causing the fans to run so I got a belt and a sensor diconected the batt and Installed . Powered back up and started no help same 142 dig cooling.. Any help would be great
Thanks Dan
Thanks Dan
