1986coupe
I am not sure how to tell if I am having ECM problems or a bad ground.
I often here strange sounds in the radio before the service engine light or coolant light comes on. The numbers on the air conditoning do not always come on ( I already fixed the air conditioning so that isn't the problem)
I was reading my Haynes manual last night. I noticed the testing for the EGR solenoid because it could also be a bad wire or ECM. I used the tester and the light didn't work from one of the wires. As I was testing it the air conditioning fan came on. Is this a bad ECM?
Any help is most appreciated.
