B
bawile81
Hello Everyone ;
I'm hoping to get help with a problem I have had for some time now. Any sugestions will be greatly appreciated.
Starting from the intitial problem. The car would miss and stumble while driving. This was intermittent. It finally threw a code #23 - Open or Grounded Mixture Control Solenoid. I replaced this solenoid. All was well until a short time later and this car stumbled again and even shut off. This time No Codes but the catalytic converter went bad. A friend said I could bypass this so I ran a straight pipe.
Things ran fine for a short time again. Then it started shutting off again. This time a code #42 - EST Circuit - I replaced the ignition module and the HEI coil. This worked for only a couple of days then it shut off and wouldn't start. (Cranked but no spark). I got off of work and removed the negative battery cable to reset the computer. When I hooked it back up the Car fired right up.
It has not set any codes even though it will shut off. It does this sometimes even when just ideling to warm up. ( I have noticed that I have to kick the choke off ? It doesn't seem to go off on it's own)
Awhile (the beginning) back I tried another computer but the problem was still there so I put the old computer back in.
I have replaced the Spark Plugs, Plug Wires, Cap, Rotor, Mixture Control Solenoid , Oxygen Sensor , HEI Coil and the Ignition Module.
This problem is intermittent and I don't have a clue to what is causing this. It doesn't set any codes and I would think it would when it shuts off.
I don't even like to drive it anymore as I don't know when it will let Me sit.
Thanks for ANY help...
bawile81
bawile81
